Headlight Vibration Dampener Broke
06-20-2012, 10:44 PM
Quote:
Originally Posted by
crankme30
Hey I know its been over a year, but what did you end up doing with your headlight? I just had the same thing happen taking my headlight apart to powdercoat the bucket..... Did you use a solid stud? Any problems with vibrations?
Thanks
I used a good flexible glue. I plan on changing the headlight at some point so i figured i would change it if the dampener broke again.
It doesn't seem to affect it at all and the glue actually holds extremely well.
06-20-2012, 11:39 PM
tke899
You can buy just the rubber mounts elsewhere from HD.
Specs:
.75" wide
.38" tall (3/8")
1/4-20 threaded studs
They're male-male vibration isolation sandwich mounts. Takes some research on Google, but you can find them. About $2 a piece.
Edit: Filter by width to .38
https://sdp-si.com/eStore/Direct.asp?GroupID=522
Reason: Added link
10-05-2012, 02:01 AM
Debrix Cycles sells these.
ShrinerRider
05-21-2020 02:43 PM
SDrake65
04-23-2013 06:23 AM
veniculum
09-08-2006 12:18 AM
1984fxrs
06-09-2006 12:28 PM
pococj
08-01-2005 12:07 AM
back ,
bucket ,
damper ,
davidson ,
deuce ,
harley ,
headlight ,
headlignt ,
motorcycle ,
mount ,
put ,
rubber ,
softail ,
vibration ,
vibrations
