I have a new set of grips for my bike. Swapping the throttle grip is easy. But what about the left side? I can't get the factory hand grip off. What's the trick here?
If you have an air compressor, you can use an air gun and stick it under the edge of the grip and pull the trigger. The grip should start to lossen up an slide off.
If you want to save it, take a long thin screwdriver and slide it under a bit work it up and down and back an forth, squirt some WD40 keep doing it and it'll come off quite easy... Just gotta mees with it a bit.. Old hacksaw blade will do it also but may break.
