my bike is making a noise
Ok my 09 deluxe is making a tinging type sound when its in a slight bind. Say for instance, if im running along in 6 th gear and go to pass someone if i give her a lil throttle or a pretty good bit of throttle it makes a ting ting noise. Kinda like the noise you hear when your exhaust is cooling down. Is this normal?
I've also noticed a pinging sound when I cross a bridge or go through a tunnel....or get too close to a retaining wall....I've ridden other big Harley and they did it too. We figured it is some sort of resonance from the belt echo... or some other moving or rotating part....this is more of a zing....zing....zing....and....this is not a problem.
If its pinging...and you confirm it...throttle up under load at low rpm in higher gears...then post back and we can work on that for you. Pinging....if its really bad....can ruin your day...and a couple of paychecks.
First thing....fuel. Go premium...if u have it available...see if nearby SUNOCO station is selling CAM2...get a thankful for grins...if no pinging..then its fuel. If you opened up the intake and or exhaust (stage 1)...then u need to think about an aftermarket computer so you can adjust afr and timing. For now....if u can ...throttle and gear in such a way so as to avoid what you already know is gonna happen....a little warning ping ok...lots of ping ...bad.
Just read that...no...no...no.....u got to use premium. Man..I even spring for CAM2 from time to time just to boost the octane up....matter of fact...use up that 87 soonest...and if u can find it fill up with CAM2....problem solved.
i will try that tomorrow and pray that it helps. i was told by a mechanic that i didnt need to run a high octane gas so much for that loosers opinion, huh. thanks guys i will let yall know the outcome.
We all live and learn.
