HID Install?
Old 02-21-2011, 12:06 PM
aesconde's Avatar
aesconde
aesconde is offline
6th Gear
Don't have pics of the install, but this is the finished product.
Its a D2S bixenon projector, and a Denso ballast. I had to fit the ballast inside the Nacelle, otherwise, I would have had to cut away a large part of the headlight casing to get all the wiring through. Powered with a direct line to the battery and relayed to the headlight switch. Light output is 100x better than the stock halogen bulb.
Old 02-21-2011, 01:44 PM
banginTwins's Avatar
banginTwins
banginTwins is offline
nice.....
Old 02-21-2011, 01:45 PM
banginTwins
yeah that is why I want to put all 4 ballast inside nachelle for same reason
Old 07-13-2011, 05:17 AM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
I never put a ballast inside of an enclosed headlight bucket. I have seen other friends such as Motowheels in CA do it and 100% lead to the ballast turning off due to extreme heat build up. Every HID manufacturer I have ever dealt with plainly specify the heat range the ballast will operate in. Inside of a Nacelle is fine but not in a bucket.
Wakko47
02-17-2013 01:21 PM
WideBoy04
04-18-2010 12:20 PM
eric95
10-21-2008 11:24 AM
jcbpa
09-27-2008 06:31 PM
Bigstick
09-18-2008 03:42 PM
Quick Reply: HID Install?
