Tuner and factory warranty
Hello, this is my questions and situation, I have a 2011 fat boy lo, and I'm looking at having a set of Vance and Hines big radius 2-1 and a SE heavy breather installed with either a TTS mastertuner or a Seprt. My motors stock for now, I only have 600 miles on her. Situation 1.... If I go with Seprt I would be done and tuned by the dealer.. With no warranty issues...Situation 2.... The TTS would be done by an Indy, who is recommended , is very comfy with the tuner, and he says it will not affect the factory warranty.... I understand if he screws something up he's responsible, but IF there was a warranty issue would MOCO turn there head because it's a TTS tuner.... I still have time to think about and digest any responses ... Because I like to do this after my 1000 service.... I'd like to get a good relations with a good wrench, and the Indy seems to be the answer....and the dealers is good.... But there well........ A dealer...... Thanks
The dealer tries to scare you into using "their tuner" and will tell you all kinds of crap to keep you from buying elsewhere. The short answer is NO, it will not void your warranty to install an aftermarket tuner unless they can prove that it damaged your bike. Dealers look at people as sheeple, meaning that you will just do things the way they tell you too, but if you stand up to them they usually back off.
Was at a dealership a while back near where i live, not the one i bought my bike from. They were selling the Power Commander V there in parts and asked if they install, will it void the warranty. He said technically yes if the PCV causes it. Then he said that basically so does the SERT because it's for offroad use or something. Maybe it depends on the dealer, or there all just full of sh$t, it just matters how full of sh$t they are. Either way i put what i want on the bike, it's mine!
That is totally correct, it has to cause the failure for them not to cover it. I have seen it where it has happened but in most cases they just fix the bike and return to the owner
