Inner Cam Bearing Failure! Engine toast! Important Question - Help
An inner cam bearing (top cam) failed on my '04 Fatboy. Gail's HD in Kansas bult it to a SE 103 at 1400 miles. 264 cams, CNC heads, pistons, SE fly wheel, tappits, but NO CAM BEARING UPGRADE (probably not available) and NO ROLLER ROCKERS. No one bothered to tell me to check the condition of my cam bearings due to the poor design of Harley's cam chain tensioner system etc. So after 10,000, or who knows, miles of my upper cam spinning in the bearing seat of the case with a disintegrated bearing, my entire engine is toast. The seat in the case is warbled out so bad the cases have to be replaced. The pistons are galled to the max, the oil pump is crap, the cams are shot, the cylinders are scared, the tappits are gone etc. etc. etc.
So here's my question:
With all that metal in my oil, and the fact that the same metal laden oil lubricates the bearings of my $1,300 flywheel, would you chance putting the same flywheel back in the new rebuild?
Regards,
Brent
Regards,
Brent
Increased valve spring pressures make it mandatory to up grade cam bearings in a Twin Cam. The builder should have know that!
The bright side is that you have a perfect opportunity to get an engine upgrade. I like the look of the Crazy Horse motors, but they are still limited to 100 cc builds ( and I am not sure of fitment).
S&S makes a good engine, and only reason to not get one is because they are so popular in after market builds that its expected.
Just my two cents though, I don't know enough about em to really make an informed opinion.
