Rocker box help
Old 01-30-2011 | 11:29 AM
harleylay's Avatar
harleylay
Question Rocker box help
I need some help I have a 95 softail 1340 and goin to replace the rocker boxes. I have the front one off cleaned everything changed and ready to install. I can not seem to get the new one on it seems like the pushrods are to high I didnt mess with any of that. Is there a trick to this any help
Old 01-30-2011 | 11:51 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
There's three pcs to the rocker box's. Please be a little more specific on what your changing.
Old 01-30-2011 | 12:20 PM
harleylay's Avatar
harleylay
Im changing all three on front and back heads Im having problems getting the bottom one on.
Old 01-30-2011 | 12:57 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You need to rotate the engine until the push rods are in teh proper place to install the rocker boxes. With the bike on a lift and in gear, turn the rear wheel and watch the pushrods until they move down a bit lower, or until the other cylinder is at at TDC.
Drew
Old 01-30-2011 | 03:12 PM
V-Twins & Bowties
If your changing it all just remove the pushrods and covers. Without mixing them up of course. Install the bottom piece then replace the pushrods and covers.
If rocker arms are installed remove them before installing the bottom box. Then with the box and pushrods installed replace the rocker arms.
You've baffled me as how you got this all apart without having to do some of this. That being said........ things always come apart easier then they sometimes go back together.
ATTENTION ATTENTION
This post was made while not thinking clearly. I was in the mindset of adjustable pushrods when I wrote this. I apologize for any miscues.
ATTENTION ATTENTION
Old 01-30-2011 | 03:16 PM
V-Twins & Bowties
Make sure your center and top piece is flat check them on a piece of glass or stone counter top. Also tighten the four top cover bolts in small increments to ensure that they do not "squeeze" the gasket out. I've been through this.
Old 01-30-2011 | 04:35 PM
V-Twins & Bowties
Drew
After my above posts, if you have stock pushrods this is what you need to do.( see quote ) Be aware that the lower box , once aligned and in position, will not sit flat to the head because of the lifters pushing up on the rocker arms. As you tighten the bolts the lifters will bleed down and you'll be set, once you can spin the pushrods, rotate crank and repeat process for other cylinder.
Old 01-31-2011 | 09:13 AM
harleylay's Avatar
harleylay
So your saying I need to take the rocker arm off the bottom box. Will the push rods push down as I tighten the box down
Old 01-31-2011 | 09:21 AM
V-Twins & Bowties
I sent you an E-Mail. Did you get it?
Old 01-31-2011 | 09:32 AM
harleylay's Avatar
harleylay
No I guess I have taken spark plugs out turned the wheel pushrods at lowest point now if I sit the rocker box on the head does not sit flush so if I start tightening the 4 bolts will pushrods go down as I tighten just don't want to screw anything up
Quick Reply: Rocker box help
