Newbie Questions About a Few Things on my bike
Old 01-29-2011, 06:27 PM
MilwaukeeMike's Avatar
MilwaukeeMike
MilwaukeeMike is offline
6th Gear
Default Newbie Questions About a Few Things on my bike
So we had some balmy (32 degree) weather here today, so I started monkeying around with my bike.
1.) The dealer adversited the bike as having a "High Flow Air Cleaner" when I bought it last month. It's the one question (among many of them) that I forgot to ask before taking delivery on my 2004 FLSTCI Heritage Classic.
I removed the air filter cover and confirmed the element is K&N. The filter itself measures in at 2 1/4" inches tall. When I view available parts on the K&N website, it appears I might have 'custom assembly' P/N RK-3910, because that has the element measuring in at 2 1/4". This makes me assume it isn't "just" a drop-in K&N filter available on their site, or the other custom assy measuring the element in at 1 5/8" tall. I didn't see any P/Ns on the assembly.
If my assumption is true at this point, that's awesome!!! (It's listed at $194 and adds 12.05HP at 5000RPM.) Whaddya think?
2.) I removed my bags today (gonna be ordering gotsaggybags kit soon) and noticed a plug of some sort just kind of hanging near the rear of the oil reservoir. It does have a cover on it. What is it? Diagnostics connector?
3.) I attempted to remove the seat(s) today to get access to the battery but couldn't push down the left side passenger seat strap bracket and wasn't about to start pounding it down with a hammer. I don't have any 'star' wrenches either. What gives? Should I buy a set and loosen it up a bit so I can push the strap bracket down to get it off?
4.) Finally, my manual indicates there is a transmission fluid dipstick somewhere, but I couldn't locate it. They made it look similar to the oil dipstick.
Thanks a lot for taking the time to help a noob out!
Old 01-29-2011, 06:33 PM
jlasoftail's Avatar
jlasoftail
jlasoftail is offline
The "star" (torx) wrench is a must. Go buy a set to fit onto your ratchet wrench, and buy a fold up set to fit in your bags. The bike is full of them (or at least my 09 is) and you can't do much on the bike without them. I can't tell you much about the air filter. There are a million different sizes. And with a different tranny I can't really comment on your dipstick, but I doubt it would be like the one on your oil tank.
Old 01-29-2011, 06:37 PM
Mike T's Avatar
Mike T
Mike T is offline
That covered connector is for diagnostics.
Old 01-29-2011, 06:44 PM
tunaman's Avatar
tunaman
tunaman is offline
First and foremost, get yourself a service manual for your year model bike... they are a must have.
Second:
Third - the transmission dipstick should be attached to the bolt-on cover on the right rear side of the motor, if it is like mine. You have to remove it with an allen wrench if that is the case.
Roger
Old 01-29-2011, 07:03 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Second:
Roger
Get the Harley service manual. It will answer all these questions. It will be the best $60 you ever spend on the bike. Is the backplate the filter is attached to round like the filter? If so you have some sort of aftermarket air filter setup. Probably a big sucker or screaming eagle deal. The tranny dipstick is in the top of the tranny with a large allen head that unscrews it.
Drew
Old 01-29-2011, 08:44 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
The plug could also be a battery tender connector. But with no pic or detailed description who knows.
+ + + on the service manual.
Old 01-29-2011, 09:07 PM
2 Dogs's Avatar
2 Dogs
2 Dogs is offline
Like the other said post some pix...agree with Ih4x4 it could be a battery tender...easy way to tell is follow the wiring and it the wires go directly to the battery terminals its a tender.
Old 01-29-2011, 11:13 PM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
Yeah, you are going to have to post up some pics on just what you are calling the left side seat strap bracket. There may be a difference between an 04 and 2011 Heritage, but my passenger seat has two "U" brackets that just slide into the two screw on nuts. The passenger strap pulls over the front of the seat and also attaches to those brackets.
Old 01-29-2011, 11:14 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Repair manual and pictures!
Old 01-30-2011, 12:05 AM
rjg883c's Avatar
rjg883c
rjg883c is offline
I have a Sportster so it might be different on your scooter, perhaps someone else knows? But there are several places on mine that need a "star" (torx) size 27. And that is not included in any sets I have seen. So you might need to get a T27 in addition to a set of torx bits.
Ron
Quick Reply: Newbie Questions About a Few Things on my bike
