I was detailing my bike this past weekend after riding all day Saturday & Sunday, and while cleaning the around the voltage regulator I found a build-up of a grease / oil mix. It looks like there are 2 leads running to the regulator and each lead has a rubber boot at the end. Also, instead of the normal shrink tubing, each lead is encased inside a fiber / canvas?? sleeve. This sleeve, both the leads, and all inside the VR area is saturated with a oily greasy mix. It doesn't drip, there are no spots on the garage floor, and it didn't fling off while riding. Anyone else seen this on their bike, or know where it could be coming from? It hasn't run down from someplace else, it's only around the VR. I'm thinking the dealer might have spilled some oil when they did the last service on it while changing the oil filter.....any thoughts?
My guess is that it's the neck bearing grease and it's coming from under your triple trees and handlebars. They always put too much grease in there and as you ride it comes out and makes that mess for a week or two. Once it's drained to a normal amount, that will stop.
I put a chin spoiler on my new (170mi) FB Lo last week and had to disconnect the regulator to do so. The connections were full of what I think was a dielectric clear grease. Could that be what your seeing? Maybe thy over did it on yours?
thanks for the suggestions....I took an oil pad and wiped the whole area clean last night,. Gonna' check it again after commuting all week and see what happens.
I think he pegged it. Id be willing to bet thats what its from. Mine on my 08 Fatboy dripped and threw grease like crazy for like a month. The one on my Luxe hasnt done it as bad.
Mine got that way from oil filter changes. The way our regulators are mounted is a horrible design due to where the oil filter is. I now pull my regulator completely when changing the oil. The EVO's were great being on the frame.
