Where can I find these ...10Hr search = fail
#103
-1 oz. bag for 80 - 120mm width motorcycle tires (BMW's use 2 oz.) and 10" scooter wheels.
-2 oz. bag for 130mm - 240mm width motorcycle tires, BMW's, and 12" and larger scooter wheels.
-3 oz. bag for 250mm - 360mm width motorcycle tires.
#104
#105
Get the tube tire installed on the wheel first.If there is air in it let it all out.Get a valve stem remover,remove the valve stem.Can be had at your local Hardware Store for like 4.00 bucks.Then the kit comes with 2 packs of beads.1oz for the front tire up to like a 130mm and 2 oz for the rear up to like a 240mm tire .Put the beads in the bottle they supply, than attach the clear hose to the bottle and the other end to the valve and drop them in slowly.They will get jammed up if you put them in too fast .Just tap on the valve with a screw driver it will unclog it and they will drop right in.If you have a small electric engraver etc that works even better for the clogs.Just turn it on and the vibration against the valve will release the clog fast.Put the valve stem back in,fill with air done.I got mine at Rocky Mountain ATV cheap,super fast shipping and great customer service.And some of the best deal on motorcycle tires you will find any where period.
#106
My7 yr old son did my front tire for me gave him 2 bucks ,While I sat back watched and had a beer.It is that easy!!
#109
#110
