HD Ignition Problem
RE: HD Ignition Problem
Please do not take this as disrespect or thinking that I am a know it all. After 8 years of being a mechanic I have found that some of the most simple things are missed even by the most sesond of mechanics. Start with fuses and relays first, they are the cheapest items to replace and they are usualy the problem with electrical. Next make sure all grounds are conected properly and clean (rust free). Next the battery, making sure it is conected snugly at the terminals and free of corrosion. Check the switch making sure all wires are conected and clean. Lastly, scratch head and ask like you did. The odds that some one else has had the same problem is high. Like madmax1 before me said check the coil. He does make a good point about borrowing a part because this are expensive to just start changing. I used to keep about 50 different coils and 5 or 6 different ECM's and so forth and so on just to check car's and truck's that had problems. Good luck, and forgive the miss-spelled words I normaly cut and paste from word so that I can spell check.
With no power anywhere at all, I would look at the ground side of the battery cables but at the end where it joins the bike, not the battery end. Also check by the rear of the tank where the ground wires from the bike are bunched up and bolt to the frame (grounded). Don't take anything for granted, remove and clean them. As a last resort, use a test light clipped to the POS of the battery and work through the ground circuit starting at the NEG of the battery and working away from the battery. This is not always the best way of doing it because the smallest connection will light the light but will not run the bike. It's used only to locate an OPEN circuit.
Quick way of testing if it is the ground circuit is to use a battery jumper cable attached to the NEG of the battery and connect it to a good source of ground like the engine case itself and try to start it then. If it starts, then you know where to look for the problem .
I had something similar happen to my 05 Springer Classic....lookked at all the relays, fuses battery etc....while at the parts dept. One of the guys walked by and asked how many miles? I told him 3,000 he said funny thing we had a fat boy in here with same mileage and similar problem. There was a pinched wire from the fuse box to the starter and after 3,000 miles it rubbed down to the wire, shorting out the system....so went home and damn if I didn't find the same thing. Moved the wire where it should have been in the first place, a little black tape and all was well.....20,000 miles later no problems at all......hope you find the solution!!!
