HD tool 44455 know where to get one?
I have tried the dealer and some specialized motorcycle tool dealers no luck. It is the tool for removing the snap in oil lines.
Removing the oil line is no problem but inside the oil tank fitting is some additional o rings etc that i believe the tool is needed for.
Mark
Mark
Here's an older thread about this very issue..
https://www.hdforums.com/forum/softa...oval-tool.html
Mike
NY
Mike
NY
back again (08-01-2020)
I swapped out my tank and didn't use any tool to remove the lines. just squeeze the 2 plastic wings and pull the line comes out. to reinstall insert the plastic fitting in the tank and snap the lines back in. you will see it is an easy operation. It has to be for the kids at the dealer that work on these things
Like above, I replaced the oil tank on the Nightrain and did not have to use any tools at all to get the line out, just a small scribe to reach in and get the old 'o' rings out of the hole.
Just rock it side to side and pull slightly while squeezing the plastic clips. Might help to get some new clips from the dealer first if you never seen them so you can get a feel for how they clip in.
