A Few Ape Questions
A Few Ape Questions
i'm looking to put apes on my 03 night train but have a few questions first. i'm looking at probably getting a set of 16", i'm 6' and wonderig if that sounds about right. i switched my seat to a corbin solo so it sits kind of low. also i was wondering what size of risers most people are running and what length cables i would need to get? i've read about people talking about norrow and wide. what is the difference?
Personally, if I was using 16's on a Softail with that low seat, I'd be reaching- especially while turning. I also prefer the look of the short (2") risers with apes, but that's just personal preference. Now, I'm a little shorter (5'10") than you, but I have a Softail with a Badlander seat and the 14's are just right. They work good for me on my Road King, too.
Most handlebar manufacturer's can advise you on cable length, etc. That's why I use Wild 1 brand- very knowledgeable folks.
You basically have a Wide Glide front end on that Night Train, so my advice is to go with the wider apes, but again, personal preference.
Good luck.
Good luck.
Going by what has been mentioned on here before....sit on your bike with both arms out (as though grabbing your apes) about where you feel is most comfortable and have some one measure from your hands down to the top of your trees.....subtract the riser height from your measurement and and that's the length of apes you want to order.
Example: my measurement was 14-15 inches ( I didn't want my hands above my shoulders), I wanted short risers...1 1/2 inches, wound up with 12 1/2inch apes.
Most common length cables are posted here, just have to search after you decide which size apes you want. HCC has done all the calculations for you if you order from them.
Narrow or Wide? Depends on what looks good to you. Just make sure the Apes you order fit your trees (width)
You can go to the magnum shielding homepage at: http://magnumshielding.com/ which are identical to the HD cables. Magnum shielding have all the stock lengths and the plus up length sizes...great reference. As to play it on the safe size I would measure the distance with a piece of twine and route it exactly as you would the cables...then mark the twine and measure (thats the most effective and safest way). As for risers on 16" apes, I would go with a 1" or 2" for maximum stability, if you start going with tall risers you will lose more stability with speeds in excess of 70mph. Good luck on the bar swap.
thanks guys. it looks like i need to go out and measure to see what it says. why is it that some peoples apes lean forwards (like ash16's) some straitup (like TW's) and some lean back towards the seat (i don't really care for that look) how can i make sure mine are strait up if not alittle forwards?
If the tach itself can rotate, you could mount it on the upper bolts of the riser top clamp, but that might require a new mounting plate since the holes are further apart.
