Just push on it with your foot until it's all the way over. I mount using the floorboard on the right side and dismount the same way, stand has never failed.
Huh? When I park I put the kickstand down, pull back a little and park in gear with the front end turned all the way left. I've never understood the people I've seen straighten the front when parked (it's not power steering), but I've never even seen one turn it to the right - isn't that as unstable as you can make it?
Well, it is I guess. The last time was in the garage, I had the front end cranked to to the right so I could get my oil pressure sendding unit out. I got up and walked over to the bench to get something and it swung around to the left but stayed upright. It's usually when I need the bike upright as much as possible to do something underneath on the left side. The HD center stand I ordered will make it easier to work on it, especially when cleaning the rear wheel.
I find myself kicking mine forward a couple times before I lean her over. Sometimes, it just looks like she is on her way over, but never had it happen.
I do this as well as pulling back as the stand sets in place.
My buddy dumped his dyna because he didn't have his all the way forward. He knew what he did and has never had it fall again. I kick mine all the way forward then rock it back and then forward a little to make sure it's engaged. It scared the begeezers out of me when I first got the bike, but I've never had an issue.
If bike is used check stand 1 time, If bike is new check stand 2 times, If bike has more money in mods than you can remember check stand 2 times and pull back, then put large pillows around sled and then fasten 2 cables to the front and 2 cables to the back tighten by fastening to concrete with hilti gun!
Heck, I've never given mine a second thought. kick it forward and it settles in as I roll off the bike. Now you guys are going to make me pay more attention.
