Need help with Heritage Backrest
Use Goo-gone liberally to get the rest of the crap off.
You will find that the screw is a normal philips head screw. I wanted to put an HD medallion back there, so I had to use a 1/2" counter sinking bit to countersink the hole and I used a countersunk screw so that it would be flush to the back plate.
The last picture was before I cleaned it up, but you get the idea.
Yep, and the leather is held on by some NASTY double stick tape. Use a blow drier to warm it up, and I used a paint stick which I sanded to a sharper blade edge to pry it off.
04FXDI
02-23-2018 10:21 AM
