going from 2 to 1 pipe to 2-2s
I need some advice folks. I haven't had this bke long and love the chit out of the power but dislike the sound. First harley first efi. sooooo, not sure what all is entailed in changing pipes to some 2 ito 2s. I realize I'll lose a bit in the power dept but I'd rather be happy with the sound. I've got SuperTrapps one her now and would like a good, not the most expensive set of 2 into 2s made. not real long and fairly free flowing but with baffles for back pressure. I want a good sound Harley "crack". I don' really want to have to find somewhere to get a dyno run, will this be necessary? I' don't wanna have to jack with the Screamin Eagle Race tuner, heres' what the rest of my ride has in it:
2003 Heritage Softail Classic EFI : Hot Shot Motorworks Heads 1.94 intake & 1.625 Exhaust valves Crane Roller Rockers Crane adjustable pushrods Cycle-Rama custom ground cams .630 lift S&S limited travel lifters Axtell 117cu.in. cylinder kit 11.1 compression Screamin Eagle 4 3/8" stroker crank welded and trued Timken Bearing crankshaft upgrade Compufire 3 Starter Fueling oil pump Horsepower inc. 55mm throttle body w/ yellow band injectors Screamin Eagle race tuner Upgraded Harley Davidson primary chain adjuster Speeds performance spark plug wires Screamin Eagle clutch spring upgrade Supertrapp 2-1 Exhaust Chrome DNA 21" 53 Mammoth Spoke Rims, Headlamp Nacelle give old school nastagic look, powder coated black drag bars, ness grips, RSD Contrast Cut intake.
If you could give me some clues on some good pipes, not real long, loud is fine, that will require nothing but a normal install I'd appreciate it.
Thanx for any input,
Bob
Bob
Supertrapps are known to be a quiet pipe. Unlike other pipes, they are extremely tuneable and a good choice when you want the most. With your large build any 2n2 should be plenty loud. lol Had VH Big Shots Staggered, and even in my lil cammed 88" they sounded really good. Too loud on loooong rides for me though. The prices have dropped on these so check out eBay. Also, hit up some bike shows/rides to look and listen to pipes. You should retune the bike after changing to a 2n2, especially given that build. That bike must fly.
wahog, hows the black holding up on your lowcat? do you have any more photos? Im thinking of getting one for my fatboy,Ive got a chrome fatcat now ,I would never go back to the bss , everybodys got them here where I live, My fatcat sounds nasty,and has great low end torque. Bsod IF you go to a 2-2 from a 2-1 I really think you need to retune to run the best it can. Im sure that bike was tuned for that pipe with that build. If you go to another 2-1 id say ,no
zcastle25@gmail.com
01-03-2016 12:59 AM
