Cam lope
No, this is NOT TRUE. I've got the Woods 6-6's with stock compression and I have a great dyno chart. The 555's are just minor variant's of the 6-6's and they run great with or without higher than stock compression. Hell, Jamie at fuelmoto installs these all the time with stock compression and the results are great. And to the person asking about nice sounding cam lope with the 555's, yes they have a great sound to them.
Re: Cams
My Rocker has the lope you seem to want. it is a little of a pain in slow traffic, as the bike doesnt come up in RPM without a little bucking. OH, almost forgot, i have the Screamin Eagle 255 cams. they are called "Torque Cams". i can certainly lug this engine to death and just crank it on and the bike accelerates. I have done just a "few" other mods to this engine also. if i am crusing at 50 or so, i always have the bike in 6th gear. most other bikes seem to only like the 6th speed at interstate speeds.
just my 2 cents.
pat in tennessee
2008 Rocker C- FXCWC
SE Stage II 103 Cu. In. Big Bore Kit (1690 cc) 3-7/8”
SE Pro 4-3/8” Stroker Flywheel and Rod Assy.
SE Pro (MVA) Heads
SE Pro 58mm EFI Throttle Body
SE 255 Cam (Torque)
SE Roller Rocker Arms
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark PLugs
SE Pro Tuner Kit
Vance and Hines Big Radius Exhaust
SE Stage 1 Air Cleaner Kit
SE Hi Flow Billet Air Cleaner
FXCW Luggage Rack Kit (Now Chrome Plated)
FXCW Seat
Custom Fabricated Sissy Bar (polished stainless steel)
just my 2 cents.
pat in tennessee
SE Pro (MVA) Heads
SE 255 Cam (Torque)
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark PLugs
SE Pro Tuner Kit
FXCW Seat
