FXST won't idle, warm, without enricher pulled out a little
Did the bike come from a higher elevation?
The first thing I would check for is a vacuum leak. Spray some water from a spritzer around the carb and heads with the bike running and as little of the enricher it will stand and see if the idle picks up. If it does, you have a vacuum leak.
Before I went to messing with the carb you can have someone take an AFR reading at the end of your pipes and see if the bike is too lean.
C#
C#
sagebrush1976
Exhaust System Topics
08-18-2011 08:11 AM
