Chrome Front Lowers
Old 11-29-2010 | 04:42 PM
Twofields6's Avatar
Twofields6
Default Chrome Front Lowers
Getting some Chrome Lowers for my 09 Heritage Classic. Just looking for some info. on the change out difficulty.
Old 11-29-2010 | 05:00 PM
Fatboy Brian's Avatar
Fatboy Brian
I did some research on the forums before attempting the project, seemed complicated. I was scared to death to tackle the job. Its turned out to be a pretty simple with the proper tools. Just do your homework before attempting.
Old 11-30-2010 | 09:45 AM
Nickrc3's Avatar
Nickrc3
I just replaced the lowers (sliders) and fork springs this past weekend on a ElectraGlide. New chrome lowers and lowering the front end.
The only really obstacle is setting the bushing and seals within the lowers. This was easily accomplished with a tool made from a 18" length of 1-1/2" PVC pipe (18" was necessary in order to extend out beyond the slider tube and allow you to drive the bushing/seal into place). The outside diamter of 2" PVC will not fit inside the FLH slider tube, and 1-1/2" would not fit over the fork tube. Easily solved by carefully cutting a 1/16" slot throughout the length (parallel w/ pipe) of 1-1/2" PVC. Cutting an 18" straight line can be tricky with a handheld jigsaw (a table saw w/ blade depth set is best), so I used several layers of blue masking tape to form a fence which the jigsaw base rode against. The PVC tool can now be effectively 'spread' (w/ screwdrivers) to fit around the fork tube and the 18" length extends away from the slider tube. Use a block of wood w/ rubber mallet to drive the bushing and seal (lube both w/ fork oil) up against the machined stop within the slider tube. Both easily drove into position. One thing, use the existing 2" steel washer up against the rubber seal (not to damage seal) and ensure correct placement, as one could easily install the seal backwards.
The other thing I observed is an excessive torque rating (IMHO) for the 6mm slider bolts. I used the minimal setting, and still felt it was a bit too much.
Hope I didn't confuse you too much.
Good luck.
Old 12-01-2010 | 10:40 AM
rbg00600's Avatar
rbg00600
Have an 06 Heritage Classic, if I swap have chrome lowers installed, do I need to also swap out the cowbells/uppers?
Old 12-01-2010 | 10:51 AM
Fatboy Brian
you don't have to but it would look like crap, the stock cans are stainless.
Old 12-02-2010 | 12:14 AM
Bluehighways's Avatar
Bluehighways
I used an old seal, after cleaning off the rubber on the old seal with a wire wheel, to act as an adapter between the PVC pipe and the new seal. Doing it this way there was never any contact between the PVC pipe and the lip or soft rubber parts of the new seals.
Old 12-02-2010 | 08:03 AM
Bugsplat's Avatar
Bugsplat
I used the same method for installing the fork seal as Nickrc3. I would also take extra precaution to wrap the cowbells as they scratch and dent super easy - this happened to me so I ended up having to replace them. If you don't feel comfortable pressing in the fork seals, you can talk a dealer into doing for a nominal charge (that was my backup plan) - they quoted me between $25-50.
Old 12-02-2010 | 06:05 PM
Twofields6's Avatar
Twofields6
Excellent feedback everyone!!! I appreciate it, just got them in the mail today so wish me luck - gotta get the cow bells first though.
Old 12-02-2010 | 09:03 PM
McRider's Avatar
McRider
Make sure you check them at the store. There were some quality issues with some of them.
Old 04-23-2011 | 01:19 PM
Twofields6's Avatar
Twofields6
Smile
Got em on and a few other mods too.
Cappyvol
06-03-2024 11:40 PM
Mnvrod
06-21-2019 02:49 PM
skiddd
11-29-2014 05:06 PM
sendtorandy
03-12-2011 05:50 AM
HDV-GLIDE
01-09-2010 04:29 PM
