Hard Starting When Warm
When the bike is cold I don't have a problem starting it. However, once it gets warm, it takes 2 to 3 tries. The starter kicks in, engine turns over but just keeps turning. Sometimes the starter will stop, start and the motor kicks over as soon as the starter kicks in again. A couple of times while starting I got a puff of white smoke from behind the AC. Also, when I park the bike in the garage after a ride, the garge smells like gas a few minutes later, indicating I'm running rich.
I spoke to my Indy about it and he suggested I disconnect the Fuel Moto PC and just go through the ECM and see what happens. I did that and the problem continues - no change at all. I let the bike idle for several minutes to warm it up, turned it off and tried starting it. I needed to push the start button anywhere from 2 to 3 times to get it to fire up.
Any suggestions what could be wrong? Oh, starter clutch replaced last winter and batter is kept on a tender. The battery is only a little over a year old.
Man,
I had that same issue on two of my bikes, with a world difference between them.
On my Ninja ZX6R it was the carbs needing of a clean with gummed stuff in the jet passes.
On my 01 FXST, it was the fact the bike was running too rich, once it was leaned out, this disappeared.
When I my Indy said he'll lean the bike out, I thought "what is he smoking, what does lean or rich have to do with warm starting?" but I'd be damned since he did that it has been 2 years with no issue !.
Now I know yours is Injected, but keep in mind that it maybe running a bit too rich.
My X-bones does that if its warmed up to a pretty good temp. If I just ran it and didnt really stop she starts alright but if its slow traffic it takes a crank or two to get her running. I dont think much of it... since she always starts... never smelled gas though that might be an issue.
chevdude
10-09-2017 10:10 AM
jumccaff
08-18-2014 05:32 PM
