Rocker C Mods
I am getting ready to pick-up my Rocker-C in a couple of weeks and was looking for some good ideas/pics for mobs I can do to the bike. I have read on these forums that a lot of people don't like the seat because it is uncomfortable. I would like a seat that closes the gap between the stock seat and the rear finder because I will be riding solo and that gap is not very appealing to my eyes. So if there are other Rocker C riders out there, give me some ideas/suggestions.
Thanks.
Thanks.
Plenty of ideas in this thread---> https://www.hdforums.com/forum/softa...ctures-55.html
That is a very nice seat...what is the model # of the seat? Did you have to do any additional modifications to the bike in order to install that seat?
I agree with your mob about the license plate, I have seen a lot of Rockers with this modification, so with that said, what did you use to fill the holes left behind after removing the license plate holder? I would like to use an option that doesn't include having to paint the bike.
Thanks.
Thanks.
One additional question, has any one replaced their turn signal, brake and head light with LEDs? If so, where did you get here from and that where the item #s?
Thanks for all the great ideas.
Sorry, forgot to answer your other question, No mods were necessary to install this seat, except removing the plastic cover over the battery. To answer your lighting question, the tail lights are led from the factory. I have all Headwinds lights on my bike but kept the factory setup: standard fronts, led rears. If your bike is an '11 you may have electrical issues changing the fronts to led due to their lower draw as the electrical system is quite different on the new bikes.
Look over the different styles, http://www.dannygray.com/HotSeats.asp?D=1
No mod necessary to mount it other than remove the stock seat and support.
I did use polished stainless bolts and washers instead of the bolts and washers supplied with the seat.
