Integrated LED Tail Light/Turn Signal
I found this tail light replacement on the net today. Looks like a great way to clean up the rear on a Heritage and others. Does anyone have any experience with this set-up?
http://www.2wheelscustom.com/2004-up...ts-signal.html
http://www.2wheelscustom.com/1999-20...ts-signal.html
Click on the picture on the 99-03 model link to see it in action.
Check out the Cycle Visions Eliminator. It is not inexpensive, but it works great and really ties the rear end together. I have read of a lot of people with the Kury one that have had issues with the LED's burning out or the board going bad in the light.
This thing is REALLY bright! And, the signals come on in amber while they are red running and brake lights. It also give 3 very quick flashes when you hit the brakes. It is one of the nicest things I have added to my ride thus far and well worth it as a safety feature due to its brightness.
Drew
Drew
I recall reading a post awhile back regarding integrated turn signals and tail light. The poster was pulled over because the state motor vehicle code required a certain distance between the turn signals. It's probably one of those rarely enforced codes but it's something to consider before buying.
I have the Kuryakyn unit, and have been using it since 2008 without issue. I'm happy with it, and like the flasher and the fact that the turn signals are integrated, so it provides additional visibility from the rear.
Check local state laws to see if you can use an integrated unit without external turn signals.
Roger
Roger
