Spray Painted Primary Cover and Oven!
The amount of time needed to cure, is measured by the amount of heat that is constant. Like I said, If you bake it for 20-30 mins at 225, that will be more than enough for the paint to cure and attached to the surface. The other guys are correct you need to rough the surface up, then take it smooth with a finer grade paper, to take down the rougher spots and make it even all the way around. That way it will all look the same with no high, low, spots. Take your time makin sure to do the entire surface the same. It will pay off in the end and shouldnt chip if you do at least 3 coats with oven time. I suggest letting it sit for 24 hours between coats. Do one coat with heat, then let sit, then do another with heat, lightly sand before the last coat and heat, then sit for 24 hours, and you should be VERY PLEASED. Besides when you do something yourself, it makes you appreciate it more. Good Luck Bro, its gonna look good man.
Awesome, thanks... i put a couple of more coats last night and some more overn time. i only did 15 minutes at 200f... do you think i should just pop it in the oven again tonight?
this quote is going on my archive of DIY... thanks for the info. I followed the can's instructions and now it makes total sense. the can says either apply second coats after 5 minutes or 48 hrs... i didnt know why.
i have used the home depot stuff on some other things and it looked like asses IMO... i have used the krylon flat black or textured they sell at o'reilly or Autozone, that looks pretty good and hasnt chipped. the can said wait 15 minutes before force drying... thats what i did.
if it chips i'll do this... i only did 15 min
Just my 2 cents....
