fuel moto efi tuner question
Unless you have changed out your cam's you could always put the stock A/C back on and you should be fine.
Fuel Moto (Jamie) is one of the best guys I have ever delt with I am sure he will go out of his way to take care of you.
One of the main issues with the PC series on softails is the mounting room and wires, mine died after about 200 miles due to a pinched or broke wire and Jamie sent me a new one no questions asked.
As for the cranking longer before starting. If you run into this problem try starting it BEFORE you hear the fuel pump shut off (like half way through the pump cycle). Trust me on this one. It worked every time on the nightrain.
I assume you were talking about the power commander in the orginial post.
