Is this the battery charger plug?
Old 11-15-2010, 05:58 AM
ImNoPrince's Avatar
ImNoPrince
ImNoPrince is offline
Originally Posted by ShockwaveTXB
Looks like this would work...I have a trickle...
http://www.powerlet.com/product/powe...uty-cables/315
that has a ground point not shown on the larger dia black piece it may not work. There is no step on the one on your bike. I agree with others if your not going to use it take it off and just use a tender lead.
Old 11-15-2010, 07:06 AM
ShockwaveTXB's Avatar
ShockwaveTXB
ShockwaveTXB is offline
Ok thanks for the tip.
Old 11-15-2010, 08:18 AM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
Don't confuse the term Cigarette Lighter Plug, it's an accessory plug and could be handy for use in a lot of ways. However this type of plug is NOT designed to use with a heating element that is found in older cars for the cigarette lighters. Just the name of a common 12 volt accessory plug. It can be used to charge the battery, I wouldn't use it for jump starting purposes.
Many chargers come with additional connections for maintenance purposes and you can place them permanently on the battery and leave that plug where it can be easily connected and disconnected. Most use a simple 2 pin flat plug.
Old 11-15-2010, 09:09 AM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
Originally Posted by ImNoPrince
I'm sure they used that to run either a CellPhone charger or a GPS.
+1 and maybe heated gloves or vest of some sort
Old 11-15-2010, 09:19 AM
HOG_0308's Avatar
HOG_0308
HOG_0308 is offline
Originally Posted by FrozenInTime
Looks to me to be a power source for accessories.
+1...
the other owner must have worked on the back to the future car.... and decided work on your bike also... get rid of it and get yourself a Harley Tender.... problem solved...
Good luck
Old 11-15-2010, 01:11 PM
oct1949's Avatar
oct1949
oct1949 is offline
Also thinking heated clothing..
09IronRider
Milwaukee Eight (M8)
10-22-2017 09:42 PM
salty_rider
04-16-2015 06:14 AM
kjr2492
08-30-2011 11:10 AM
eravo
12-23-2010 02:25 AM
brackers
03-17-2008 12:49 PM
Quick Reply: Is this the battery charger plug?
