wobbling in the curves. How to fix?
Old 11-12-2010, 08:41 PM
missedem's Avatar
missedem
missedem is offline
Default wobbling in the curves. How to fix?
twisty curves make the back end of my heritage softail wobble like a rowing machine twisting from side to side. It gets so bad that if I dont slow down im gonna eat it. Put progressive fork springs in the front . Tightened up rear shocks twice. Any suggestions on how to fix this would be appreciated.
Old 11-12-2010, 10:12 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Sounds very dangerous to say the least. What year, how many miles? Did it happen prior to progressive springs installed? Fork oil? Check tire pressure, inspecting tires (ie cupping), wheel bearings, swing arm bushings, check/adjust headset bearings, rear wheel alignment.
Old 11-12-2010, 11:56 PM
roqueweiler's Avatar
roqueweiler
roqueweiler is offline
sounds like your spokes may be loose and wheel(s) may need re-trueing.
It is a common enough problem that I check mine at least once or twice a season.
Old 11-13-2010, 06:01 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
Check the rear tire and wheel, most likely the cause is there.
Old 11-13-2010, 06:46 AM
handyhoward's Avatar
handyhoward
handyhoward is offline
If most of your riding is conservative straight up and your rear tire has "set in" to a specific pattern, when you start rolling over onto the side tread there is often a "lurch". This is due to a ridge which has formed between the most used part of your tire and the unused side tread of the tire.
Old 11-13-2010, 06:58 AM
Doug45601's Avatar
Doug45601
Doug45601 is offline
what he said!
Old 11-13-2010, 07:32 AM
Lwb1376's Avatar
Lwb1376
Lwb1376 is offline
check steering nut, that what i found on mine.
Old 11-13-2010, 07:42 AM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
BLKnCHRME09Deluxe is offline
loose spokes....
Old 11-13-2010, 09:46 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Check the spokes was my first thought.
Drew
Old 11-13-2010, 02:37 PM
Navychief's Avatar
Navychief
Navychief is offline
The wife was having a similar problem on her Deluxe. Checked the spoke tension, no help. Opened the service manual and adjusted the head/neck bearing and the bike tracks straight as an arrow and the wobble is gone. I personally don't like doing more than one thing before checking the problem again, too many fixes done at once leaves me wondering exactly what the problem was.
Quick Reply: wobbling in the curves. How to fix?
