fender rails on Deluxe
Old 08-26-2015, 10:50 AM
steveodeluxe's Avatar
steveodeluxe
steveodeluxe is offline
1st Gear
Default 2011 Deluxe with heritage fender rails and 21 mammoths
Here is my 2011 deluxe. Did not attach that little screw and eventually busted at weld points and snagged front tire. Probably better to either bend forward and self tap a small screw or remove tab and clear silicone/glue so it doesn't snap after a couple thousand bumps! Waiting on new fender rail and tire now to do all over again because its a great MOD!
Originally Posted by steveodeluxe
Old 08-26-2015, 12:48 PM
Dom Poww's Avatar
Dom Poww
Dom Poww is offline
Just did the front for my 2012. Very easy - I used the silicone on the front tab and its stable - no issues. Next for me is the rear fender.
Old 08-26-2015, 12:54 PM
steveodeluxe
1st Gear
I know but there isn't much room between my fender, the tab and my tire. I actually started shedding the tire about a month ago and cut the tab off. It seemed stable and then eventually the welds on one side snapped and it nailed my tire and was ripped off and hanging. Could have been worse just a warning. I am putting a new one on but this time cutting tab off clean before install and then mounting some sort of bumper between rail up front and nose of fender.
Sfblczy
12-16-2018 09:35 PM
wingshootin1275
07-12-2013 10:40 PM
Aaresz
02-27-2013 12:05 AM
Reino_79
08-19-2011 12:45 PM
hdgzr
03-24-2011 08:27 PM
Quick Reply: fender rails on Deluxe
