For all the naysayers...next time you change oil in your car only use 3 quart of fresh oil and top up with the used oil you just drained. I sure you could drive for years that way...
WOW LMAo
are people really that cheap?
just something I would never think of doing
i guess while your at it you could pull the cam cover and pour the extra outta there that the other plug doesnt get out and also take the valve covers off and get the puddles outta there also. I guess it just depends on how **** a person gets on getting all the oil out to me the risk/reward isnt worth pulling the plug
Dont pull the pipe plug at the bottom of the the crank case. it only empties the sump and if everythis is working correctly you will only get a couple of ounces at most out. You do run the risk of cracking the cases when you install or creating a small leak so its not worth pulling it.
about 28 ounces is left behind in the sump. check out the scavenger on line for removing the oil from the sump. There are also a few articles on how to make a device for clearing the sump on this forum
