Feels strange around corners and curves
For the past 2 days it feels as if the back end of the bike wants to break loose around a curve or corner. When I weave the bike left to right on a straight I get the same feeling. I checked the tire pressure - good, checked the shocks - no loose bolts.
It's hard to explain but the rear end feels "loose" whenever the bike goes into any kind of lean.
Suggestions on what else to look for?
Might be the preload needs adjusting some for your weight. Has it ever been adjusted? I just had the ride height tweaked on my bike and it made a world of difference. It has a lowering kit on it from the PO and I was bottoming out two up. Took it to indy who raised it about a 1/2" he said. I believe the shocks themselves are set at factory "full soft" setting but that 1/2 inch made a world of difference in the feel of the bike through turns. She feels more planted now and much more confident in the curves. Just a thought.
