help with top rocker box cover install
10-23-2010, 05:09 AM
Gents, in the process of blacking out the engine and want to put on a set of rocker box covers - upper housings only! Is this simply a case of removing the tank, bolt off and bolt on with new gasket? I dont have to drain oil etc etc do I?
Any advice greatly appreciated.
Cheers
SnakeEyes
10-23-2010, 06:17 AM
I wouldn't think you'd have to drain oil because of that damn gravity law....I don't know for sure though
10-23-2010, 07:35 AM
No draining your oil. When you use the same covers again the gasket is only for your peace of mind. Tighten the bolts as mentioned.
10-23-2010, 10:31 AM
Take off, put back on. Just follow the torquing procedure and bolt order in the manual.
Drew
MNtadpole
Engine Mechanical Topics
06-03-2019 10:04 PM
jt metal
07-30-2015 05:29 PM
deanp1964
Exhaust System Topics
12-12-2011 07:44 PM
Speedkingnick
07-24-2007 07:03 PM
GothMetalGuitarist
08-15-2006 06:46 PM
box ,
boxes ,
cover ,
covers ,
davidson ,
evo ,
gasket ,
gaskit ,
harley ,
install ,
installation ,
instaltion ,
rocker ,
softail ,
top
