How To: Old school passing lamp mod with PICS (bulb changing too!)
I just made my passing lamps yellow with the help of Lamin-X that was suggested by a fellow forum member. You know who you are and thanks! This mod took 5 minutes, including cleaning the bulbs. I also took a few pics to show how to change the bulbs if you want to add 55W bulbs. I avhe had no issue with them burning out...yet. We'll see how that works out as I have been warned by Mimo. I am thinking if your bulbs are not lasting very long it could be your ground causing them to fry or excessive vibration, but I do not know for sure.
Passing lamps on with bright
Passing lamps on with low beam
Headlight no passing lamps
Here is a passing lamp removed from the bike and housing. Unplug the power and ground wires to remove. If you avhe stock passing lamps bulbs that are "sealed" use a screwdriver or sharp knife to GENTLY pry the rubber boot off of the bulb. These are on with a ton of glue. Take you time to ensure you do not rip the boot. Here is how it looks once removed.
To remove the bulbs, undo the clip and take out bulb. I always use the power wire to remove it so as not to touch the bulb itself. Force of habit. I changed the bulbs last week so I did not do this right now.
Now for the yellow Lamix-X I got. Clean the bulb thoroughly. I used lemon pledge. I must have watched the pledge commercial that says to use it on bikes just before this.
Here is the Lamin-X. Peel off the backing (holding it by the tabs to prevent fingerprints, not in directions). Apply to the light an ensure you do not ahve bubbles or ridges. It will peel back and stick back on if there is a problem. If you want to a real man use a plastic application card to get it on there, but I did not find this necessary. When you are finished it will look like this.
Put the light back on the bike. Plug in ground and power.
One yellow, one regular
Both done.
Both on
Both off with headlight
I have an extra set of Lamin-X in yellow as their website was not clear on if 2 came in a package. 2 come in a package but I ordered 2. I will sell for $12 shipped. PM me if you want it. It was $17 plus shipping from their site.
Thanks!
Drew
Both done.
Both on
Thanks!
Drew
They are yellow, but not amber. If you want amber you should get amber lamps. Someone makes them. They look darker with the lights off. The only thing i don't like about the tribar is that if you look closely at the round piece in the center it's cut kind of funny, but I have been known to be **** about stuff like that. I guess if no one wants it I'll just leave it on.
Amber lamps
http://compare.ebay.com/like/2206601...=263602_304662
Drew
Amber lamps
Drew
Looks good. The yellow lens sets it of nicely.
Is it just the pics or are the passing lamps and turn sigs less bright on hi beam? On low beam they get brighter. And with the passing lamps turned off, your turn sigs are very bright. Looks as if the wiring is undersized for the added amp load. Or it could be wired differently. Maybe its just the pics...
