I got a couple problems...Help!
The front is breaking in. My Deuce did the same thing ( tree frog) for a bit but then stopped. As far as the rear?? Sounds like the belt but let your HD figure it out.
BTW, How is Mebane ,NC? I always wanted to get there as my last name is Mebane also and ancestors are from there. Sharp ride by the way. Looks good.
I did that. It gets better all the way up and progrssively gets worse as I come down. I looked in the manual and it call for 5/16-3/8" deflection with a 10lb gauge. All the way up I could hardley deflect it 1/4". I lowered it to my normal riding height, abjusted it and it got better. I'll check it again tomorrow and re-adjust if necessary. The brake pads are HD pads. I had just put some Lyndall pads on before the accident and HD wrench said to replace the pads with new ones for the new rotors. So I've got some practically new Lyndall pads.
HD FBOY
07-16-2008 07:29 PM
