Problems installing O2 sensors on new V&H Big Shots
Hello,
I have a 2010 Fat Boy Lo and just purchased some V&H Big Shots. The install went smooth up untill I had to install my O2 sensors. The won't fit, it's like to holes on the pipes are too small. Has anyone ran into this? Should I tap the threads out alittle?
Thanks for listening!
1. remove exhaust
2. unplug o2 sensors from the connectors and take note of the cable routing
3. install sensors on exhaust
4. install exhaust
5. connect o2 sensors plugs
o2 sensor thread size is standard, they should bolt on directly to the new exhaust, otherwise contact exhaust seller....
O2 bungs are two sizes (15mm & 18mm). Make sure you have the correct set of pipes for the year/model & they are easier to install when off bike vs. on.
deal with fuel injection if you install a high flow ac
Hey just food for thought.
I put vh short shots on my xbones this past weekend. The o2 sensor on the fron pipe went on no problem. But, the rear pipe was an issue. The o2 sensor would not go in....tk the point where it began to strip. Since i was dealing with xpensive o2 sensor and pipe i decided to bring the bas pipe and o2 sensor to my exhaust garage buddiea. Sure enough, when they looked at the threads in the ot hole on the pipe they were all jacked up ( not from me ). They said it looked like whoever made the plug threads messed it up. So, they just retapped the pipe for me and the 02sensor fit perfect.
We prob got pipes made by the same "new guy " at vh!!
DO NOT TAP ANYTHING!
If the pipes are correct for the bike, the O2's will fit without any issue. Pull the pipes carefully disconnect the sensors making a note of how they go back and which is front and back. Put them in - DO NOT FORGET YOUR ANTI-SIEZE AROUND THE o2 Sensor (THREADS ONLY)
You should be fine
You should be fine
