Problems installing O2 sensors on new V&H Big Shots
Old 09-29-2010, 10:59 PM
SoCalH-D's Avatar
SoCalH-D
SoCalH-D is offline
I had to chase the threads in my pro pipe before the O2's would thread in.
Old 09-30-2010, 12:23 PM
saplg8's Avatar
saplg8
saplg8 is offline
Stage III
Thanks for all the responses. I emailed V&H and verified I received the correct pipes.
Here's what they said about the O2's not fitting.
"This is do to excess plating accumulated on the threads. It is normal procedure to clean the threads with a tap. You can purchase an 18mm by 1.5 thread pitch tap through your local hardware store, or you can take it to your local muffler shop to have the threads cleaned up"
Old 09-30-2010, 12:46 PM
Joe Diver's Avatar
Joe Diver
Joe Diver is offline
That sux. My Samsons came ready to go and the O2's screwed right in.
Old 09-30-2010, 07:53 PM
Rakthi's Avatar
Rakthi
Rakthi is offline
My V&H true duals O2s went in without a problem ... lucky me ... Well at least you know they did a good job plating your pipes!
Old 05-09-2011, 01:57 PM
bluesman409's Avatar
bluesman409
bluesman409 is offline
Stage III
I have the same problem as sapl8.
I'm installing V&H Big Shots Long on my '08 Fatboy. Pain in the *** to be honest. My O2 sensors start to thread then stop before seating. I don't want to force them in. It's the same on both ports.
Old 05-09-2011, 02:09 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
In 2010 or maybe it was 2011, there was a change in 02 sensor size. I though it was just the touring bikes, but not sure. You said the hole in the bike was too small? The change in size was TO a smaller size.....
Old 05-09-2011, 03:24 PM
poppavein's Avatar
poppavein
poppavein is offline
I had no problem with my Samsons either.
Dang, forgot the anti-sieze ...
Old 05-09-2011, 04:33 PM
1hellbent's Avatar
1hellbent
1hellbent is offline
I had this discussion with an engineer ay V&H last fall. I bought a set of double barrel staggereds and when I went to put them on, I discovered that they didn’t mask the bung threads when they plated them.
I told the engineer that I had a set that didn’t get masked and he said they don’t mask any of them any more. I asked him if he was kidding…he said nope! He said that if the O2 sensor is too tight, try chasing the threads with a tap. I said, hows about you guys chasing the threads before you stick it into the box, that’s ridiculous!
Try going to a hardware or auto parts and finding an M18x1.5 tap. That’s about a 35 dollar tap from an industrial or tooling supply, you ain’t going to find one in a hardware store.
I ended up borrowing one from a machine shop customer of mine.
rossWG
Exhaust System Topics
04-29-2018 10:41 AM
caoboii
06-19-2017 11:49 AM
jefla
02-24-2015 08:21 AM
The Ground Truth
02-23-2010 09:12 PM
Snoman_333
05-24-2007 02:11 AM
Quick Reply: Problems installing O2 sensors on new V&H Big Shots
