Clutch Problem
09-20-2010, 01:08 PM
Clutch Problem
How long should the clutch on my 2007 softail last?
09-21-2010, 06:34 AM
09-21-2010, 11:08 PM
+1 to tk353. Depends on your skill, riding style, fluid type and interval...and maybe recognizing the need for adjustment before its too late.
09-22-2010, 01:31 AM
Depends on how well you've kept it adjusted. The harley clutch is one of the strongest parts of your bike, until you let it get out of adjustment.
09-22-2010, 09:33 AM
Quote:
Originally Posted by
Other Sheep
+, the adjustment procedure is stupid simple. Do it every service.
09-23-2010, 08:25 AM
09-23-2010, 03:03 PM
Thanks for the help Gent's. I think I let it go to long without adjusting... I guess it's time for a Hot Rod clutch!!! anyone have any recommendations... or should I go back with an HD clutch
09-23-2010, 03:49 PM
did you adjust it in the primary to get your slack back??
09-23-2010, 04:23 PM
First thing I did was loosen the cable, then I took the Derby cover off, loosened the locking nut on the clutch, I then used an Allen wrench on the adjuster bolt, loosened it all the way, then turned it back in until I felt it start to tighten, then turned it back 1/2 a turn and tightened the locking nut... put the cable back on the lever and tightened it up until I had about a 1/8" of slack in the lever.
09-23-2010, 08:53 PM
29,743 and it still like new in our 07...
66C10
07-18-2016 06:07 PM
Velocity1
07-28-2013 08:35 AM
blackchipjim
07-03-2012 01:57 PM
Blacklion213
02-16-2009 11:30 AM
ULTHD
05-20-2006 09:05 PM
