Need Help! Rear wheel problem.
I put the spacers on the correct sides its hard to mix up one is a .5 in. the other is like 1.5in.
So then the rotor and pads were changed together? If so, are you sure you have 1. the right one and 2. have it all installed correctly?
You also didn't tell us, did you compress the piston before putting it together?
I would also not ride it, even a little bit like that or your new rotor may be toast.
I spread the old brake pads apart before removing them to compress the pistons.
Custom
Sounds like you got a lot of engineering going on. You need to pull the pads, remove the two spacers. Ensure the pistons are fully back in caliper. Since I assume your left side belt side was OK before with the 1.5 spacer put it on with the wheel mounted and float the caliper with out the .5 spacer till pistons are centered on rotor and adjust the .5 spacer as necessary with a lathe. You may end up with a shim forward of the caliper spacer arm hole. If your determined to use mis-matched parts you got to make them fit. Doing this type of work requires the tools and skills of a mechanic,machinist,engineer and if you are asking questions like you ask up front you need to farm this out. Good luck. Not trying to be blunt. Just do not want you to cause an accident. This is far beyond word of mouth help. If you were up the street I would fix it for you and no one gives better prices (all I ever expect is someone to be there and watch) since I do it as a hobby and have 46 years in a machine shop world behind me.
If it was mine, from what I have read here, I would find an 1/8" washer, and add it to the outside of the spacer between the spacer and the brake caliper arm. That is if you have room to get it in there. Either that or get a new spacer made. I had to replace one of my spacers a while back as the chrome was flaking off. Harley don't give those babies away at like $23.00. I should have just made one out of a piece of pipe, but then it would not be chrome.
