Hertiage neutral ony start
Sounds like something in the starter relay is not right. Heck my 02 Deuce will start without pulling the clutch in and in gear! Been there done that after a couple of beers. Boy did I feel like a dork. You might check your relay out for something loose or dirty. If I recall correctly the sequence for circuitry is: Battery, starter/ main circuit breaker, ignition switch, ignition circuit breaker, then start switch. When you push the start switch it sends a signal to the relay which sends a signal to the starter/solenoid. Because it will start in Neutral leads me to believe something is not right at the relay.
There is a switch in the clutch lever perch on the handlebars. Take a flashlight and look in there to see if the lever is acuating the switch, or if the switch is damaged.
That would be a place to start any way.
Note: An 02 Deuce will not have the switch, as they didn't start using the switch till 07.
Yea Faast Ed,I changed the levers to some chrome Kero ocki something anothers to purty it up some and after taking a flashlite out there as suggested by Chester1957, it is not activating the switch. I guess I will need to revert back to stock unless I can find another chrone one to work properly. Thanks guys....................
