master tune
08-31-2010 | 08:15 PM
master tune
hey guys what do you think about the master tune. I have a fxsti with stage 1 and br 2-2 what kind of results do typically see when tuned on a dyno?
08-31-2010 | 10:34 PM
I don't kmow about the dyno tune with it. I used the V-tune program that came with it and it worked great.
08-31-2010 | 10:52 PM
Quote:
Originally Posted by
av8or
Same here.
09-01-2010 | 09:01 AM
+1 on TTS Mastertune. I did not have the best of luck that the other posters had with using VTune, but I believe it was due to me (not the product). I ended up taking it to a dyno tuner (JD's Cycle Works in Bethlehem PA) and could not be happier. Bike starts right up, runs strong, and has virtually no decel popping. Overall, I would recommend this product.
09-01-2010 | 09:09 AM
TTS is a great system. the only reason I am not running it is that for my 2002 they do not have the v-tune. And yes, I can get it for you.
Drew
09-02-2010 | 04:19 PM
06fxsti
Here is before and after dyno tune. I did not want the bike to be tuned as a dyno queen (Max HP) but wanted the best low/mid range performance.
Vance&Hines Double Barrels
SE Heavy Breather
TTS Master Tuner
I never shifted into 6th gear below 60mph. After dyno tune the bike slides into 6th at 50mph and pulls better in 6th than it did before in 5th.
09-02-2010 | 08:34 PM
thanks guys for the input going to roar at the shore in n.j. and hoping that kuryakyn is there so that I and my buddy can buy the 2 bike kit.
09-03-2010 | 12:32 AM
If you can wait , I would contact "Dr V-Twin" he might be able to get you a better price!
Also, don't forget to buy the cables!!! Your regular cheap cables will give you lots of problems. Better to buy the ones from TTS.
sanlyn
07-06-2012 02:38 PM
t059736
05-11-2011 08:13 AM
acmo.sch
04-29-2011 11:51 PM
Biggzed
Harley Davidson Videos
03-23-2009 05:55 PM
street glider ac
01-31-2009 08:13 AM
