T-Man Cams
I'm not familiar with the 555 cam. I have the T-Man 625 cam. T-Man knows how to make horsepower and his components do what he says. Did you talk to him and get his recommendation? I had several conversations with him before deciding what to go with. He didn't try to sell me anything and went out of his way to help. A satisfied customer will tell 5 people and an unsatisfied customer will tell 25 people. You need to get the setup that fits your style of riding and meets your expectations. Let us know how it works out!
It all depends on what you want, Before I put a 107" kit in my 10 WG it had woods tw6-6 cams but the biggest power gain in the seat of the pants was when I put the Evo. gear kit in the primary it was a huge difference in the way it pulled. When I upped my 07 NT from 107" to 124" I called Tman told him what I wanted and my riding style and he set up a package for me with all the best components and made for low and mid range power- It Rips having it dynoed tomorrow. But I feel that just a cam upgrade is not taking full advantage without head work and gearing you can now use 6th gear. Tman makes big power I have the 662-2 cams matched with 124- thumper stage 4 heads 202 intake 195 ext. and 58 mm pro TB and tons of other stuff will post dyno sheet later. But just call around and take your time for you may want to upgrade further at a later date.
T-Man makes the best!
T-Man makes the best! The best stuff, the best performance and the best service. ABC H-D (Waterford, MI) Svc Mgr Walt Smith put together a package with the help of TR to get me numbers I did not expect! 110 HP/113 TQ. Now this is running .010" over flat-top pistons with static compression of 9.5. No pre-detonation!!! Motor has TM-600SM cams, stage II heads, roller rockers, SERT, 50MM SE TB, Stage !! breather, SuperTrapp 2:1 ceramic pipe running with 15 discs and no end cap. My ride is a '07 FLHX. Other than the pipe and the air cleaner, it looks stock. There is generally a head or two turned in it's direction when it's first fired up. Torque curve is nearly flat through most of the power curve with peak HP output at 5700rpm. It pulls VERY hard through all gears.
