Pic of Fatboy Lo rear signal relocation kit
Old 08-23-2010, 09:12 PM
Earl IV's Avatar
Earl IV
Earl IV is offline
I've been waiting for a month for mine too.
I just took the signals off.
Does anyone make a back plate for the tail light with signal mounts?
Old 08-24-2010, 01:24 AM
tk353's Avatar
tk353
tk353 is offline
Originally Posted by Matt990724
What did you grind? where?
http://gallery.me.com/tk353#100418&b...lack&view=grid
Old 08-24-2010, 05:36 AM
N3WWL's Avatar
N3WWL
N3WWL is offline
The rounded portion on the back edge of the side plate interferes with the turn signal at the rear mount. I simply installed the mounts and held the side plate in position to see how much needed to be shaved. I have gloss black side plates and just used some blue painters tape to mark a line and protect the plate at the same time. I estimate approximately 1/4" was removed. I used a bench grinder and ground off to the tape line. I then used a fine file to smooth out the edges. No damage to the plate finish at all. Just take some touch up paint and a small brush to finish the end where the grinder was used. It looks like it came that way now. Those turn signal relocators are ugly when compared to the wedge design of the O.E.M. signals. I highly recommend this modification.
Old 08-24-2010, 06:02 AM
Anthony16's Avatar
Anthony16
Anthony16 is offline
I installed the relocation kit also and I hate it. I'll be doing the backrest mod this winter. Thanks for the pics
Old 08-24-2010, 06:23 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,256 Likes on 4,783 Posts
I bought the relocation kit, didn't like it so I made my own out of a couple pieces of flat stock. Just drilled holes in each end, bent it and attached it to the most rearward holes in the struts. Most of you wouldn't want it anywhere near your bike but it works for me.
Old 08-24-2010, 05:20 PM
Matt990724's Avatar
Matt990724
Matt990724 is offline
TK, thanks for the pics.. is that all that has to be grinded is that little angle?? looks way better to keep the stock lights.... not to mention save some $$$
THANKS!!!
Old 08-24-2010, 06:27 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Originally Posted by jbg
Here you go. I like it better than shaving down what's there. But I like the original fin better.
My bike had those already installed. Removed the round spacers and drilled out some threaded stock to run the wires through. Detach sissy bar clears perfect.
Old 08-24-2010, 07:30 PM
Pierre's Avatar
Pierre
Pierre is offline
Default I Think you had the wrong relocation kit ...
We order this one from our dealer...
Attached Thumbnails Pic of Fatboy Lo rear signal relocation kit-photo-6247-small-.jpg   Pic of Fatboy Lo rear signal relocation kit-photo-6248-small-.jpg
Old 08-25-2010, 06:55 AM
Anthony16's Avatar
Anthony16
I'm looking at the grinded off pics. Doesn't the clamp still get in the way when its closed? I'm looking at my backrest now and after grinding off the part it seems that the clamp would still be in the way of the turn signal?
Old 08-25-2010, 07:47 AM
tk353's Avatar
tk353
tk353 is offline
clamp may seem like it gets in the way but it does not
Quick Reply: Pic of Fatboy Lo rear signal relocation kit
