heritage springer seat on a deluxe ?
Old 08-22-2010, 10:02 AM
wildrooster's Avatar
wildrooster
wildrooster is offline
Default heritage springer seat on a deluxe ?
ok just won a 98 springer seat on ebay what will have to do to get the seat to work on an 07 deluxe. I have wanted this seat since I sat on a springer at a shop and loved it but loved the deluxe a little better. is it a strait hook up for the seat or will I have to rig it to fit
Old 08-22-2010, 10:08 AM
Mike NY's Avatar
Mike NY
Mike NY is offline
I have a later year version of this seat and it's an exact fit. I have heard that the earlier versions you may have to bend the front tab a bit to get it to slide into the slot by the gas tank.
This seat not only looks great but it's comfortable as well.
Mike
Old 08-22-2010, 10:17 AM
wildrooster
bending will not be a problem. I wanted the fringe and the pipping color I got the full deal on this one only issue I think I will have is that the pad is a 95th anniversary with the patch on it odds are I will take it in to have that re-covered
Old 08-22-2010, 11:27 PM
SUUIE's Avatar
SUUIE
SUUIE is offline
Mike is right in that you have to bend the tab to fit on the EVO seats.
Old 08-23-2010, 01:28 AM
wildrooster
What's the best way to bend it
Old 08-23-2010, 08:54 AM
hspring03's Avatar
hspring03
hspring03 is offline
Bend it by hand.........Just don't put too much force on it...
Old 08-23-2010, 09:33 AM
wildrooster
That's good to know I was going to brake out the heavy gear. This is what I was trying to anticipate whether it would be a snap or a pain
Old 08-23-2010, 09:46 AM
hspring03's Avatar
hspring03
Too much force can snap the seat pan....It's a trial and error thing.....You'll see how the tab should go when you get it....
Old 08-23-2010, 12:33 PM
SUUIE's Avatar
SUUIE
SUUIE is offline
Very carefully. I think that I used vice grips.
Old 08-23-2010, 03:01 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,664 Likes on 946 Posts
You may want to remove the tab, bend it and re-rivet. Sounds like a real pain in the *** until until you crack the seat pan. Then drilling out the rivets, bending and re-riveting seems like a much easier option.
Quick Reply: heritage springer seat on a deluxe ?
