New cables, need help
I got all my new cables and bushings for my 12" apes through them.
Very happy with the service
Mine are Magnum Shielding. You can buy them from a variety of sources. The key is getting the right length. Length will vary based on the height of your bars as well as how wide they are (to some degree).
I used all +6 inch cables on my 14" Burly narrow apes. One issue I ran into was that a 90 degree bend at the controls for the brake cable didn't work that well for the +6 inch cable. It wasn't long enough with that bend. I ended up needing to order the 35 degree bend brake line directly from Magnum at +6. That ended up looking better anyway since it follows the line of the bars better.
I have found that the best way to determine cable length is the install the handlebars, have everything in place, and then install mock cables to determine the proper length required (you can use the old cables you have and then just measure the distance that remains). That way you get the best fit and the best look. Most places will not allow you to return cables once they have been purchased, so you must get them right the first time.
