Samson Long Tail Instalation HELP PLEASE
Old 08-09-2010 | 06:55 PM
Malingerer's Avatar
Malingerer
Default Samson Long Tail Instalation HELP PLEASE
Well everything is going good old exhaust off,new crush gaskets installed. new pipes prepped with flanges and snap rings.old exhaust bracket off.And then with that exhaust bracket came the passanger foot peg (right side of bike)which is attached to that bracket.The new samson bracket has no spot for the foot peg.WTF .The bike is a 2010 Softail Deluxe Did something change on the 2010,s.Called Samson they said this is the first they have ever heard of this.Any one else have this problem.And the new shifter rod at the back looks like when i install it the rear heim joint is going to be tilted facing down not straight like the factory one. Is that right???? Thanks Please all replies welcome Tom
Old 08-09-2010 | 07:04 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
yep joint if faced down on shifter rod. And take off your stock exhaust bracket and put in your foot peg. these pipes are easy easy easy to install.
Old 08-09-2010 | 08:04 PM
Malingerer's Avatar
Malingerer
Ok so the rear heim joint will be faced at a downwards angle.Samson just got back to me and told me to pop out the plastic plug above the right side foot peg and do the same for the left side.So they will be a little higher? and remove the small metal bracket attached on the left side so they will be even all around.So it seems both pegs will be attached directly to the frame.Is this what you did (and everyone else with samsons)Thanks Tom
Old 08-09-2010 | 08:21 PM
BLKnCHRME09Deluxe
Yep its been a year and a half since i installed my pipes. but i do remember just taking off the stock exhaust bracket then popping plastic plug out and installing foot peg(right side). And on the left side using the same spot for peg install.
Old 08-09-2010 | 09:12 PM
Malingerer's Avatar
Malingerer
Thanks for all your help
Umby
08-06-2013 08:12 PM
sanman4ever
07-09-2012 11:23 PM
Caseyx
03-10-2011 12:09 PM
cornishman
08-03-2007 05:10 PM
TxToy
Exhaust System Topics
05-09-2006 02:55 PM
