Transmission oil leak problem solved...
Old 08-04-2010 | 11:39 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Default Transmission oil leak problem solved...
My bike has been leaking tranny fluid a drop at a time for years. It finally buted open on Sunday's ride and I knew it was time to tear it apart. The bike is a 2002 fatboy with 52K miles on it.
I removed the primary cover and the clutch basket and compensating sprocket (without any special tools except a wooden stick) I was then surprised to find out I have to pull the oil tank to get to the screws on the back of the starter which attach to the inner primay. Therefore the oil tank had to come off. This was the biggest PITA. The oil tank is the worst part of this whole operation.
Once the oil tank was removed, I removed the starter bolts and and then all the bolts that hold the inner primary in place and it popped right off.
I discovered that the bearing race on the main shaft had walked inward pressing on the main shaft ring seal , causing it to leak. 6 hours of work for a $5 part.
I have all the parts with the exception of chrome inner primary which I am not sure if I am going to win or not.
We'll see what happens with the chrome inner primary on Ebay that ends today.
I'll get some pics up with steps later when I have time. Yeah or neigh on the chrome inner primary guys?
Drew
Old 08-04-2010 | 12:07 PM
FastHoss's Avatar
FastHoss
What caused the race to walk?
Old 08-04-2010 | 12:08 PM
tc1816's Avatar
tc1816
If you really want it then now is the time to do it. I say do it, why not everything is already apart.
Old 08-04-2010 | 12:26 PM
kk6pg's Avatar
kk6pg
General consensus on the subject is if you're putting out more than 100TQ, the race will walk. Drew hasnt got that much (yet) so you got me. Since its not an uncommon problem with stock engines, I chalk it up to "the nature of the beast"
And Drew, my vote is for whatever floats your boat. All the chrome in the world still wont turn your fatty into a Dyna
Old 08-04-2010 | 12:33 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Not to mention Larry had the same thing happen as well.
Pics.
Special Primary locking tool!
The race should be out towards the end of the shaft a bit more which would allow room to use the special tool to remove it, however since it walked in see the next pic to see how it was removed.
Old 08-04-2010 | 06:30 PM
deucer02's Avatar
deucer02
Ouch! Pucker factor definitely engaged... How much material did you cut of the race or did you go to the shaft and split the race?
Old 08-04-2010 | 06:58 PM
dennyo's Avatar
dennyo
You might as well take that Seat Post out Now ..............
Old 08-04-2010 | 07:55 PM
coronerrpm's Avatar
coronerrpm
Just looking at the pics of the fluid on the floor and the work you did made me sick to my stomach. Glad you go it figured out but still.............Hope all goes fine for you!
Old 08-04-2010 | 07:56 PM
coronerrpm's Avatar
coronerrpm
Ok, looked at the pics again and now really sick to my stomach.
Old 08-04-2010 | 08:05 PM
The Darkness's Avatar
The Darkness
I see what you mean about the oil tank.
And coronerrpm is right...makes ya a little queasy seeing you have to go in like that to get it.
As to the chrome inner, I'd say go for it. Your already into it that far....
Quick Reply: Transmission oil leak problem solved...
