switched accessory power
It's one wire I'm refering to. It's orange with a white stripe. It is a 12 volt positive wire that switches on with the ignition switch on.
For a negative, you can wire it straight to the negative terminal on the battery itself.
No prob... I used a scotchlock connector like this. Make sure you keep both sides of the wire connected and just 'tap in' to the wire. I can't remember what it powers, maybe a rear light. It's been awhile since I've done it. My bike is an '09 so based on the year of your bike, the wiring could possibly be different. Good luck!!!
Drew
