Can you put a steering damper on a Fatboy
I can see where you coming from John, but thats not what a steering damper is for; hence the puzzled responses. A steering damper is to protect you from getting into a tanksplapper (Very fast lock to lock oscillation of the bars at speed) and the subsequent crash.
The geometry/weight/speed/braking performance of our bikes is that this something that is extremely likely to happen. If anything a damper will ruin any feel you have already got
which is common on standard equipped bikes.
If something not right suggest you change the bars / check steering neck bearings
agreed
I have to agree with the rest on the fact you more than likely dont need a damper on a Harley however...most new dampers now a days are fully adjustable. I just put a new Bitubo Damper on my Ducati and it adjusts from totally free moving like there is nothing there all the way to holly **** is it ever hard to turn the bars at all. You " could " install an adjustable type like that and then play with the settings to see if you can get what you are looking for. Most good dampers are not cheap and then you would need some type of custom mount for it, could get expensive. I would go with what others say and maybe look at new bars. Then again a high end cool looking damper on a Harley would for sure look unique !!!
2 cents.
2 cents.
centennialfatboy
09-15-2009 11:27 AM
