DYNO Numbers ?
DYNO Numbers ?
I have looked in the dyno section and tried to compare my numbers with others. All that is done to mine is V&H big radius, SE a/c and a power commander-5. The dyno results I got are 70.83 HP and 85.44 Torque. I saw some others with almost the same set up and they got more. Are the numbers I got low? Am I missing something?
I am thinking of adding a cam but do not know what gains a cam will do on a 96" and if I am going the cam route do I go with heads/Jugs? I am new to these HD motors and will probably have it done somewhere. I am looking for the best bang for my buck on this.
So, If anyone can help in suggestions I am all ears. Looking for opinions on what way to go and also brands to go with as well as costs.
Thank you.
Thank you.
i just saw on tv where they took 88 and did bolt on and got over 10% increase hp and tq.
my bike would never work with a canned map. Mine went from 63.99 hp to 75.41 and 78.16 to 87.36 tq. I did rush slip ons and pc lll and big sucker. Stock was done at 91 degrees and the dyno tune was done at 68.
