Help.....caliper won't release completely
That's probably it. Brake pads tend to drag a little bit even under normal conditions. For 17 years I've heard my rear pads drag on the rotors, especially when cornering.
One more thing: when your lube the caliper pins, DON'T use "caliper pin grease" from the auto parts store. It will swell the rubber bushings and cause the calipers to hang up. Be sure you use only Dow Corning Moly 44 to lube the caliper pins and rubber bushings. Harley sends a tiny packet of it with each set of brake pads, or you can buy it on the web. It is expensive, though.
Red Dragons
06-27-2018 06:31 PM
