New Running lights, wrong relay and not working.
Old 06-16-2005, 01:25 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Default RE: New Running lights, wrong relay and not working.
It sounds to me like the instructions were wrong. If I read your diagram correctly, the switch wire from the harness was wired to the passing lamps and the white wire to the yellow low beam wire. That is bassackwards. By reversing the wires at the relay, you got them correctly wired. At any rate, glad you got it fixed. Things like that can frustrate the daylights out of you.
Old 06-16-2005, 01:39 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Glad you got it going now, they can be a real PITA sometimes
Old 06-16-2005, 02:02 PM
yodal's Avatar
yodal
yodal is offline
How about another twist to this topic? If I wanted the use the running lights regardless of running low or high beams, what source would you wire terminal 86 to? Id want the running lights to turn off when I turn off the bike regardless of turning the running lights off with their switch.
Old 06-16-2005, 02:05 PM
oldgeezer's Avatar
oldgeezer
Check the thread in the DIY section. There is a real nice wiring diagram to do what you want.
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
+12v but switched ( ignition) it would operate the relay when you turned the ign. on but you could kill the lights with the aux. switch if you didn't want them on. Would then work independent of the Hi/Lo beams
Giz
09-12-2013 12:47 PM
Damion
05-14-2012 10:36 PM
Demonsmasher
05-26-2008 02:40 PM
52edub
11-10-2007 04:35 PM
jarman
11-02-2007 09:50 AM
Quick Reply: New Running lights, wrong relay and not working.
