Leaky gas cap or overfilled?
Hey Guys,
I noticed the last few times that I filled my gas tank (09 Fatboy) I had some gas leaking from the cap onto my tank after I started riding. It seemed to primarily leak on right turns. I always make sure that the cap is on tight and screw it on until I hear a few clicks. When I fill up the tank, I do it while on the side stand and I try to make sure not to fill it above the fill hole. It is possible that I may have over filled it, but it seemed to be doing it recently. Not sure if the cap is bad or if it is just rider error. Any thoughts? Thanks.
I'd like to hear some thoughts on this too. My Heritage does the same thing. When you stand the bike upright off the stand it will start coming out. Going to try to not fill it up so far, especially in hotter weather. I didn't seem to have this problem when I got my bike new last August and through the winter though. Wonder if it could be the cap?
I had the same problem with the stock cap on my 09 Rocker. Worked fine for the first few thousand miles, then it all of a sudden started leaking after I filled up. I took it to the local dealer, and the shop boss said the overflow should deal with any overfill issues before the cap would seep, so they just handed me a brand new cap and I gave them my old one. At this point it seems to be fine again.
